  #41
Old 12-17-2004, 02:17 PM
chilichaz33 chilichaz33 is offline
chilichaz33 is off the scale
I think this company out of PA has gauges that cover many ranges, Rieker Instruments. They make inclinometers and tilt indicators.
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by TheGoodHummerMan:
Ric,
After all the discussion and reading the various viewpoints and opinions, I think I have changed my mind about how these gauges are basically useless... Just like you point out, they might provide interesting data when off-roading. Also, they would actually serve a useful purpose if, during a walk-about--- checking the trail ahead--- you could take the gauge out of the H2 and approximate the hill's slope BEFORE driving on it.
Personally, the gauges that show 0 to 45 degrees seem less useful than the gauges calibrated from 0 to 30 degrees. If you had the second gauge and the ball bearing goes off the scale, you could just say that it is "TOO" steep?
I think that the lower range of 0 to 30 would also make it easier to more accurately read what the slope actually is too...
Maybe I will use velcro to attach the gauge so I can remove it for gauging slopes while walking around?
Now I have to find out where the 0 to 30 degree gauge was available...
Ed <HR></BLOCKQUOTE>
Old 12-18-2004, 03:17 AM
unaslob unaslob is offline
unaslob is off the scale
hum2,
I have the same gauges, they are more for the passengers then for me. putting one one the overhead console is mostly useless. placing it that high on the truck and that far forward makes the device woefully inaccurate. they are only useful if as close to the center of the truck in the vertical plane
unaslob
they do look fancy though
Old 12-18-2004, 12:23 PM
Una, actually that's not entirely true. The angle of the truck is the same throughout so as long as you have it mounted correctly to begin with, it really doesn't matter where you mount it.
It needs to be perfectly vertical in the vehicle, not leaning forward or aft and obviously needs to be level and at zero when the truck is on a flat surface.
Along these lines, I am picking up a line of gauges that are a little better than the lev-o-gauges. They will come with a special mounting bracket that will allow them to mount just about any where and let you keep it set correctly. I am going to be the distributor and hopefully will have some out in the stores by the first few months of next year.
You'll be able to mount these on top of the dash, on the windshield, on the face of the dash, etc.
Old 12-18-2004, 01:43 PM
I WANT ONE(or two)!!!!
Old 12-20-2004, 12:31 PM
Texas Red's Avatar
Texas Red is off the scale
Keep us posted, Paragon. I'd be interested in one also.
Jim
2008 H3 Graphite Lux
Old 12-20-2004, 01:16 PM
Here is a example picture. I should have better artwork later this week. The base of the mounting bracket has holes and can use bolts or 3M tape. It will move 180 degrees on the vertical so you can mount it just about anywhere and still get the gauge to be level and perfectly verticle. I'll keep you posted.
Old 12-20-2004, 01:36 PM
I like it. It'll be much better for mounting on the dash between the air vents.
Old 12-20-2004, 09:49 PM
I took one and mounted it in a few different places to give an idea of where it can go. Here is pic 1
Old 12-20-2004, 09:51 PM
Pic 2
Old 12-20-2004, 09:52 PM
Pic 3
Old 12-20-2004, 10:02 PM
Fever Fever is offline
Fever is off the scale
Write me down for at least one.
T
Old 12-20-2004, 11:31 PM
RIC-H0's Avatar
RIC-H0 RIC-H0 is offline
They're all smiling at Me!!!
What a happy Option!
Ric-H2
www.meatspin.com
Old 12-21-2004, 01:22 AM
HummerLV's Avatar
HummerLV HummerLV is offline
HummerLV is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by RIC-H2:
Ric-H2 <HR></BLOCKQUOTE>
it's smiling in degrees not percentages.
Old 12-21-2004, 01:29 AM
You may have it smile at you in percentages if you like!
Old 12-24-2004, 08:18 PM
I've mentioned these to Jason but haven't officially "hit" him up about selling them yet, but Trail Duty (http://www.trailduty.com) has them in stock now if you want one. If you do get one, I think you will be surprised at how low of an angle (as compared to it's true capabilities) the pucker factor kicks in and knowing that you have more tilt available before it is unsafe.
For instance, both the H1 and H2 specs say a 40% side slope. That is about 23 degrees or so. But that spec from Hummer is with a maximum payload on board and a large margin of safety. I'd be curious to know the max angle some have been in the H2.
Old 12-25-2004, 07:39 PM
alecs wife alecs wife is offline
alecs wife is off the scale
I also use a Lev-O-Gauge and have safely traversed 40º. At that angle you have to be very careful. I feel the truck is very reliable at 35º easy. Anything above that, I get very cautious.
I agree that GM is being on the safe side.
CONFIDENTIALITY NOTICE: This post and any pictures posted with it are the property of Adam in CO and/or his affiliates. The contents of this post are confidential and may contain information that is privileged and/or exempt from disclosure under all
Old 12-25-2004, 10:51 PM
Beastmaster's Avatar
Beastmaster is off the scale
Anyone try these? These are lit:
http://www.tiltmeter.com/page10.html
M101A2 Trailer
Old 12-26-2004, 01:52 AM
Nice link!!! Did you notice they have a digital version? Might be worth looking into.
Old 12-26-2004, 02:56 AM
You can get the lit and digital versions but obviously we only have the lit in a 25 degree model right now. The biggest problem with trying to bring these to the market is the fact that you can buy the cheapo lev-o-gauges for $10-$15 and it certainly cost at least that to even make these. The problem with them though is that they have to mount flat on a perfectly vertical surface in the vehicle to be accurate.
If you see any of those at tiltmeter.com that you feel you would like, let me know. We can custom make any of these or make a whole new line. R&B is the manufacturer that I am working with on the distribution.
About the digital ones, in many situations they are not good for a quick glance since they are not a visual reference.
