08-18-2004, 07:21 PM
Need to know how to program new transmitter. I'm adding another since I only had one. (same problem on two vehicles)
1996 - Someone added a wire to receiver for programming, but I'm not sure what I need to know what to do with it. Also, working transmitter only locks/unlocks it does not activate alarm.
2001 - receiver actually has a button labelled 'program'. Again, not sure what to do, and I don't want to block out the working unit.
I would appreciate any feedback on the enabling of transmitters, and any other options allowed in the programming.
08-18-2004, 07:22 PM
Sorry for the double post- browser crashed with the first one and I didn't realize it posted.
08-18-2004, 11:30 PM
Check your PM!!!!
08-19-2004, 12:45 AM
If I remeber correcly those transmitters are individually coded meaning you need a set to make them both work. Here is a link on how to program the remote: http://www.amghummer.com/Maintenance...emoteEntry.htm
1997.5 Black Slantback
The Sole Remaining God Father
-007=
08-19-2004, 01:43 AM
Thanks ssgharkness020147 - that worked to program the transmitters! I'm going to assume the button on the 2001 does the same thing the grounding of that wire does on the 1996, but I haven't had a chance to try that yet.
I also couldn't get the horn chirp feature to be reactivated though I followed the procedure on your link several times.
Thanks again for the help, and if anyone has any idea how to reactivate the horn chirp or what I might be doing wrong, please let me know.
09-01-2004, 05:22 PM
I have an H2, ... doesn't the H1 have the same, or better, options for driver preferences?
If so, then isn't the alarm notification (horn chirp, lights, both, none) one of the dozen or so personal settings? I do not have easy access to my manual or H2 at the moment (I'm at work) but I'm pretty sure it is there.
If so, then it is just a few button pushes on your steering wheel to set it up for you (the settings are made per driver, there being two driver setups).
\"I asked my wife for a hummer, she gave me this H2.\"
03 White H2 Adventure, sunroof, Garmin GPS, Air Horns, Diablo Sport Programmer
09-01-2004, 06:09 PM
The H1 does not have all the luxury of the H2, and in fact only really has memory for 1 user vs 12.
There are no programmable buttons on the sterring wheel; in fact there are no buttons at all... not even a horn!
Unfortunately, I think the two are very different with respect to programming alarm options at least.
10-30-2004, 04:26 PM
Hi Edward. I sent you a private mail. Just wanted to say hello from Buffalo NY. I am a regular on your other well know website arfcom! Great to see you here as well.
Mark Adkins
aka: "lockedandloaded"
