04-06-2004, 06:38 PM
Nice Spike...really nice.
2003 Hummer H1 open top
2011 Mercedes C63
04-06-2004, 09:33 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by H2Finally:
NJ, is that monitor bright enough? Does it automatically turn on when u put to Reverse? That attaches onto the existing mirror right? Thanks for info! <HR></BLOCKQUOTE>
I was driving today (bright sunshine) with sunglasses on, and I had no problem viewing it at all.
It turns on automatically when put in reverse and it does attach to the OEM mirror. The sound is much better than I thought it would be.
Here is some tech info:
SAVV MIRROR
04-06-2004, 10:49 PM
Nj H2 do you mind, How much was the mirror? Also, I don’t see the temp or direction, did you lose that feature?
Joe
04-06-2004, 11:25 PM
NJ, when I was considering the SAVV, I want to take a dremel, cut-off the plastic & grind-off the silver (from mirror to clear glass), right where the stock temp/compass display is. Do you thinks this is possible? Or does the monitor's circuit board overlaps that area? Imho, yours look better than stock too!
04-07-2004, 01:56 AM
NJ, when I was considering the SAVV, I want to take a dremel, cut-off the plastic & grind-off the silver (from mirror to clear glass), right where the stock temp/compass display is. Do you thinks this is possible? Or does the monitor's circuit board overlaps that area? Imho, yours look better than stock too! <HR></BLOCKQUOTE>
Don`t dremel the silvering off. You`ll end up with an etched square. Try using a single-sided blade to scratch off the silvering and not scratch the clear glass.
I was going to buy that rearview mirror set-up but I didn`t want to lose the temp feature.
04-07-2004, 03:12 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by JMV1210:
Joe <HR></BLOCKQUOTE>
Yes, you can't see the temp and direction since the Savv mirror covers it up. It's still there you just can't see it. It was $425.00
04-07-2004, 03:16 AM
I don't know if you could do that. Personally, I wouldn't since you could ruin the Savv, or at least it's value if you ever sell it.
I don't care about the direction because I have the NAV in the mirror but I can say I do miss the temp but the good way outways the temp.
04-07-2004, 03:21 AM
NJ, after install, I doubt I'd ever remove it to sell seperately from H2. My concern was if the lcd board covers the area in front of the temp/compass. The temp is useless, but the compass is important to me, & it would suck if I need to get a stick-on compass for my cool H2!!
Dennis, the dremel was for the plastic casing. I was thinking of using a buffing wheel & chemicals to remove the silver (masking area).
04-07-2004, 09:08 AM
<HR></BLOCKQUOTE>
You might if they come out with a 6" screen
