Old 02-05-2006, 07:01 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by deicustoms:
You are right, there is a vss wire at the radio connector (on some models). I've checked out several places and people have been getting it there.
According to DirectWire, speed sense is dk. green/white pcm, blue plug, pin 21. note: Also found in the radio harness on some models. I must have the model that doesn't have it there...
I've been hesitant to do that wire though, but I'm guessing it is there. I'd really perfer to get it inside the vehicle, I hate messing with those plugs, I played with them a little and there wasn't really room to work with it.
If you have a chance to find out where I can pick it up inside the car that would be great, otherwise next time I gotta get into the pcm plugs I'll just do it then. Nav works ok, so no big rush now. thanks </div></BLOCKQUOTE>
I would suggest you use your previous referenced fantastic wiring diagrams that have never let you down, and tap in wherever you can find a speed signal.
Old 02-05-2006, 07:18 PM
deicustoms1's Avatar
deicustoms1 deicustoms1 is offline
deicustoms1 is an unknown quantity at this point
It only lists the VSS at the pcm, I guess I'll be getting it there. Was only hoping to get it somewhere inside the vehicle. I appreciate the help though.
