Old 11-18-2005, 09:26 PM
H3Eric H3Eric is offline
H3Eric is off the scale
The ABS light came on and the display had the word Failue last Wednesday. Today I drove the car and the message was gone. I will bring it to the dealer on Monday but I was wondering if the computer saves such events or can this only be diagnosed if the ABS light is on.
Old 11-18-2005, 09:42 PM
fourfourto's Avatar
Hit the onstar button if light came on they can help till you get to dealer.
Old 11-19-2005, 01:56 AM
That's the problem now. The light is off and no message anymore. I wonder if there is a history of such events in the on-board computer.
Old 11-19-2005, 11:22 AM
Most GM BCM's will hold retain codes for 40-80 igition cycles (ignition cycle defined as startup from a temp below a specificed temperature with the engine warming up to another specified temperature). I believe, but cannot verify at this time that the H3 will hold for 80 of these cycles.
The BCM is the main computer and acts as the depository of the codes outputted by other computers. So, there is a good chance if you called onstar right now, they would be able to obtain a code. If so, write it down, and give it to the dealer, just in case the codes are gone by the time you arrive at the dealer.
Old 11-20-2005, 10:35 PM
I called onstar and they could only analyze when the light was on. Next time I will call them immediate.
F5fstop anf Fourfourto thanks for the replies.
