03-09-2005, 02:27 PM
I have a Navigator and before I put it on a lift I have to manually turn the air suspension off. Is there a switch I have to turn the air suspension off on the H2 before I lift it in the air?
03-09-2005, 02:37 PM
It's called the door. No switch or anything except maybe a fuse or relay, but if you leave a door cracked open, it stops the air suspension from engaging.
03-09-2005, 08:39 PM
Same with the Navi...
Want-08 Viper, 06 M5
03-09-2005, 09:19 PM
I heard if you do not crack the door it will mess up the air suspension...is that true? DO I have to have a door open when i am rotating my tires?
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
03-09-2005, 09:53 PM
My dealer rotates my tires every time. I am not sure about that, I have heard the same before though. Something about the suspension leaking all of the air out and when the truck is lowered the bags will be flat.
I do know that there have been several updates to the air suspension programming, maybe this was taking care of.
03-09-2005, 11:30 PM
I will be doing all the "easy work" on the truck. SO I will really need to figure it out. Maybe I will call the dealer sometime this week.
03-10-2005, 02:37 PM
It might not be necessary, I know my Navi has it written all over the manual.
03-11-2005, 05:22 PM
probably your right...I will have to give them a buzz!
