Old 03-11-2005, 03:38 AM
dochummer's Avatar
So, I ran into the garage again . I left the tire carrier open, and backed up. Fortunately, I only had to replace one section of the garage door track, and a screw on the tire carrier (of course, I had to drill it out, then put a new one in, and broke that too, so...) So I ended up taking the carrier off so I could work on getting the broken screw out. When I did so, I noticed that the truck sat about an 1" higher...and it actually looked perfect! Then, I started the truck up and it self-leveled....I'm back at the original measurements . Is there a way to retrain the air suspension?
'03 H2
Old 08-21-2005, 10:10 PM
kacyk's Avatar
kacyk kacyk is offline
kacyk is off the scale
Never mind, I bought a 18 MM socket and adjusted the torsion bars myself. It's level now.
2003 Yellow H2 LUX (Sold)
Old 03-08-2005, 09:51 PM
Anthony Anthony is offline
Anthony is an unknown quantity at this point
kayck, Could you please post a pic of the fixed vehicle. I think mine is off and has been since day one. I almost did not opt for the air susp because I thought this was how all of the air susp equiped trucks were supposed to be.
Old 03-09-2005, 11:40 PM
dochummer's Avatar
I thought someone had previously said there was, but there was no verification. I was told by my non-local hummer dealership that my air suspension would probably have to be replaced. I'm sitting about 1.5" lower in the back as compared to the front....
'03 H2
Old 03-09-2005, 01:35 AM
<H1>Trim Height Specifications</H1>
<TABLE width="100%" border=1>
<TBODY>
<TR>
<TH vAlign=center align=middle>
Suspension</P></TH>
Z Height</P></TH>
D Height</P></TH></TR>
<TR>
<TD vAlign=bottom align=left colSpan=3>
Trim Height must be verified and adjusted before aligning the
vehicle.</P></TD></TR>
<TR>
<TD vAlign=center align=middle>
With RPO ZM6</P></TD>
122mm (4.8in) ±6mm (0.24in ) </P></TD>
132mm (5.2in) ±6mm (0.24in ) </P></TD></TR>
<TR>
Without RPO ZM6</P></TD>
140mm (5.5in) ±6mm (0.24in )
</P></TD></TR></TBODY></TABLE>
<FORM name=bottomNavForm>
<HR>
</FORM>
