Old 02-25-2018, 10:22 PM
Inspignant Inspignant is offline
Inspignant is on a distinguished road
Default Power steering
Greetings enthusiasts and gurus!
I had power steering and brakes go out on me here a while back. I changed the power steering pump and vacuum bled the system. Power steering was great for about a month but was slowly getting worse again. I ended up changing out the pump again as well as the two high pressure and one low return lines. Again I got the same results and it's getting bad again. There are no leaks, fluid is at the proper level and I see no bubbling in the reservoir. Is it possible that the hydroboost could be the culprit?
Old 03-27-2018, 10:00 AM
Lucky1 Lucky1 is offline
Lucky1 is off the scale
Default Re: Power steering
That would definitely be my guess. Keep us posted on your progress.
Pimpin 8 E Z but somebodys gotta do it .
Copyright ©2000 - 2024, Jelsoft Enterprises Ltd.
