Old 08-16-2016, 12:57 PM
jersey jersey is offline
jersey is on a distinguished road
Default GM Drive cycle advice
Recently replaced the purge vent solenoid which cleared the check engine light codes po 442 and po 455 figuring I could go to inspection, but when I connected my code reader and checked the I/M Monitors it shows the EVAP SYSTEM is "not ready" and therefore I can't go through inspection yet.
I did the GM Drive cycle found here about 8 times now:
http://www.obdii.com/drivecycle.html
However the evap system monitor continues to read "not ready"
Any suggestions?
Old 08-26-2016, 01:57 PM
Default Re: GM Drive cycle advice
Over 40 tries at the cycle and still the IM says "Evap Not Ready"? All other IMs report ready except EVAP. There's no check engine light, no codes. Fuses are all good. Is there a 2006 H3 specific drive cycle I should be doing?
Copyright ©2000 - 2024, Jelsoft Enterprises Ltd.
