12-03-2005, 09:31 PM
guys i just got me a new horn (the ones that play songs) and a neon kit , for the horn i need to have a controller inside the cab , is there a hole somewhere that will allow me to run a cable from the cab to the engine comparment? and i also need to find out where can i find a 12 volt cable to hook up the new horn to it . i dont know how many volts the stock horn uses . so if any one can help an this let me know thanks in advance . the underglow will be the next project.
12-03-2005, 11:11 PM
You can get a wire or small cable through a grommit on drivers side firewall pic 1.
You can tap into 12 volt(you will need a fuse on + wire) and ground at battery you must match nut 10mm and double nut it because battery nut acts as tightining bolt and will not exept a eye loop.pic 2.(You can also tap in to 12 volt in the underhood fuse panel on drivers side)
If the horn needs more than 10 amps you need to install a relay . I mounted mine on top of grill/radiator suport in existing hole on drivers side pic3
There are more pics in the tech h3 section the under installing 12 volt airhorn
pic 1
pic 2
12-03-2005, 11:12 PM
pic 3
12-03-2005, 11:40 PM
awesome i hope it plays la cucaracha
(with insurance)
12-04-2005, 01:16 PM
Four thanks for ur replys with the picts . and wannabe yea that was the reason i got it just because i want it La cucaracha but after i test it . i find out it was just like one of those icecream car things songs only so today ill return it and after doing some googling i found it here http://www.midwayautosupply.com/deta...tion.asp?11188  now this is what i was looking for ill have it by next week found the same one in another site for less.
12-05-2005, 04:01 AM
LOL your gonna get flipped off by ecofreaks and other hummer owners.
12-05-2005, 07:55 AM
hahahahahaaaa
(with insurance)
12-07-2005, 03:57 AM
Trading13 sh_t now o got me thinking  .SO how about neon kit?.  bad idea too?
