Old 06-02-2005, 11:16 PM
Mervz Mervz is offline
Mervz is off the scale
What exactly needs to be done to install the roof marker lights? I've got my order in for a Black Lux, but would like to install the lights afterwards myself, due to a discount for having an account at a local dealer.
Is there drilling? Is the wiring harness there already?
Thanks!
Thanks!
Old 06-03-2005, 01:35 AM
Hummer4Life Hummer4Life is offline
Hummer4Life is off the scale
And does it simply wire into and is controlled by the regular light switches in the car, or is it supposed to have a separate switch on the console?
Old 06-03-2005, 01:29 PM
Well, i guess i might be the first to answer this question then....
Going to the dealer this afternoon to order them, but won't be able to install untill end of July when i pick up the H3.
I assume there are instructions provided...
Old 06-03-2005, 03:49 PM
partsguy partsguy is offline
There are 5 holes to be drilled and well nuts that
are put in the holes.The harness is supplied.
I have not looked at the destructions yet,just make sure you want them,Cause you will have to live with it if you don't!
Old 06-03-2005, 08:30 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by partsguy:
I have not looked at the destructions yet,just make sure you want them,Cause you will have to live with it if you don't! </div></BLOCKQUOTE>
Yikes, the idea of holes in my roof sounds bad to me. Especially with me putting them there. I'll pass afterall...
