07-18-2006, 05:42 AM
Messing around after a Pismo trip
Mercedes-benz Technician
07-18-2006, 05:44 AM
Re: Messing around after a Pismo trip
Anyone comment on the decal?
07-18-2006, 05:56 AM
Originally Posted by GotSandH3
Anyone know of a company that might make a long travel suspension kit? You know one that gives you some flex and not just lift.
The only thing you can do for sure is a Straight Axle Swap. IFS doesn't have the same travel. The straight axle benefit is keeping all four tires in contact with the ground at all times, thus keeping traction at a maximum.
However, the ride sucks. IFS is much more comfy.
It's just not in the cards. Improving the lines you choose,and becoming a skilled driver is about the best you can hope for.
If you want to do the extreme stuff, get a rock buggy.
07-18-2006, 06:09 AM
I got a lot of smiles and people taking pictures. I was kinda upset about the performance of the H3 in the sand. My stock V6 Dakota was a lot better in it. The H3 is under powered in the sand. Almost makes me want to trade it in.
07-18-2006, 06:14 AM
Mine was awesome at Pismo....it's the tires.
07-18-2006, 06:18 AM
07-18-2006, 06:20 AM
Originally Posted by HummBebe
....it's the tires.
I agree. The stock tires suck in sand.
07-18-2006, 06:22 AM
07-18-2006, 06:23 AM
Is it too late to edit my post?
07-18-2006, 06:27 AM
07-18-2006, 07:34 AM
I only aired down to 25psi. What tires do you recommend? On the Dakota I was using Xterrains. They seemed to kick a$$. Should I stick with them? I was in 4 Hi lock and usually shifting between 2nd and 1st.
07-18-2006, 12:53 PM
Probably not low enough. They say the last 5 or so psi makes a big difference. I did better on stock tires at reg psi than I did my monster 325 Terra Grapplers at reg psi. Next time I will air down for sure.
дизель
06 H3 lux black/black sunroof, auto, monsoon, trailer hitch, 18x9 MBM chrome wheels w/ Nitto Terra Grappler 325-60-18's, Steelcraft black taillight guards, MarkM's vinyl grille letters.
03 Nissan 350z touring, 6spd, 19" chrome wheels, many mods...
07-18-2006, 04:46 PM
Yeah, probably too high. I was down to 15 PSI and still had some trouble in a couple areas. Would just lose traction on a flat area and start digging in.
The folks with mudders seemed to fair better. Kind of a paddle effect in the soft sand. Getting a wider tire will also help.
07-18-2006, 08:33 PM
im runnin the toyo mud terrain in a 315 "35" inch tire and am very happy
07-18-2006, 09:04 PM
it's the air
07-19-2006, 02:45 AM
I was thinking maybe running Bogers. Or maybe even getting a set of padle tires for the sand. Who knows..
07-19-2006, 03:51 AM
I had no trouble with the stock tires in Pismo after airing down but did get stuck in the sand elsewhere without airing down
07-19-2006, 12:59 PM
Airing down is key. 25 psi is way to high. I would think that 20 would be much better in the sand.
Rob (Ipedog - Say "Ip-E-Dog")
Black Sheep HUMMER Squadron
07-19-2006, 02:40 PM
Lower Ipe, lower.....15-12psi. That's the ticket.
07-19-2006, 02:44 PM
i ran really hard last time out at pismo with 15 psi , no issues . i think i could go down to 10 if i had to with no problem , just have to be careful not to do any high speed turns
