Old 07-09-2007, 04:43 AM
RazM's Avatar
RazM RazM is offline
Default Loud rattling sound, please say it ain't so...
*UPDATED, found the problem, check post below*
Ok, I have an early H3, build was sometime in May of 2005, so I know it falls under some of the early build problems. So far I haven't had any major issues.
Yesterday, on the way home, I heard what I thought was a rock hitting the wheel well... Soon after that, the truck started making a loud rattle, almost like a machine gun, or rocks in a tin can. I've done as much checking around as I could, and all seems well with the skidplating and nothing seems loose.
It starts around 2200rpm, at about 20mph and is heard when the windows are down, it sounds equally loud from the driver and passenger side. No sound at all when the truck is idle, and I have had NO noticable power loss or vibrations at all.
I did a search and found JustForFun's post about the problems he's had with his front diff assembly, but from the looks of it he had power loss when his noise started, and I haven't had any?
Old 07-09-2007, 05:03 AM
Default Re: Loud rattling sound, please say it ain't so...
probably the front diff bracket . check the cross-member that the front diff bolts to , and check the bolt . good luck
Old 07-09-2007, 05:12 AM
RazM's Avatar
Thx Neo! I'll give it a check, crossing my fingers
Old 07-09-2007, 12:58 PM
RazM's Avatar
HAHA! So first thing this morning I go out and lay a tarp down to check out what's going on. Everything looked good with the bolts so I kept looking for what it could be. I notice that the front driveline shaft (whatever it's called ) has a large plastic inventory sticker that is half peeled off, and that the metal pan beside it had a nice polished area to it exactly where the sticker was hitting it.
I removed the sticker and took it for a test drive, absolutely no noise anymore.
What a relief
Old 07-09-2007, 08:29 PM
new kind of sticker shock....
Old 07-09-2007, 08:51 PM
Wisha Haddan H3's Avatar
Glad it was just a sticker.
I got a scary rattling noise a couple of weeks ago on a trial. The other wheelers said it was the H3 undercarriage loosening up and making noise.
Nope ... it was just a rock bouncing around my skid plates. It bounced back out on the next rocky section.
Old 07-09-2007, 10:59 PM
fourfourto's Avatar
What a relief
Dam... it would have took the dealer 2 or 3 trips in to figure that out
Old 07-09-2007, 11:02 PM
Yea and at least 5 days in the shop.
Old 07-09-2007, 11:25 PM
Viet Nam Vette's Avatar
And an authorization From The General To Repair It...
