Old 04-03-2005, 06:40 PM
VTSTOMPER is off the scale
I need your help guys!
It's been raining like mad here, and the H2 SUT is leaking in the front ( I assume) It sounded like water sloshing back in forth through the passenger rocker panel, so I took off the step guards (on the inside of the cab seal, just below the kick panel) and it was full of water. I cleaned it all out, but I am sure it will come back unless I find the source. I NEED your help; anyone else found this on a wagon or sut let me know!!!
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 04-03-2005, 07:08 PM
ok, I have read all the "other" leak threads...I will look at the A pillar. see it it is the damn marker light. How did you all fix that? Or how did you fix the sun roof leak...I am not sure what one it is...yet.
Old 04-03-2005, 07:21 PM
drmiles's Avatar
drmiles drmiles is offline
drmiles is off the scale
SILICONE AND LOTS OF IT !!!!
Old 04-03-2005, 07:40 PM
lamp or sun roof?
LasVegas LasVegas is offline
LasVegas is off the scale
Sunroof drains have been a problem but in your rocker panel is does sound more like the marker light(s). One screw removes the lens. Then inspect the rubber boot & see if it's seated properly. Then inspect the wire going through the rubber boot to be sure it's sealed. If anything looks suspicious, seal it with RTV silicone. DON'T USE CLEAR SILICONE. Use the black permatex adhesive/sealer.
Jonahs
Old 04-03-2005, 08:00 PM
thank you guys...it's pouring now...so I have been looking at everything.
Water seems to be pouring out of the frame work that was under the kick panel. I removed the A piller cover, and it was dry under it. I assume that large hose under that is the sunroof drain hose, or one of.
The wires coming from there look to be dry...but when you remove your kick panel there are two slots with a round hole in the middle that hold the panel in place...water is coming from the hole in the middle.
Old 04-03-2005, 08:18 PM
ok, under the marker light is a hole that the wire goes down. It is not wet under the light per say...but there is water in the hole...weird.
Old 04-03-2005, 08:20 PM
VTSTOMPER...the only drains that run through that pillar is the sunroof drain. If everything else is dry above the dashboard I would suspicion a leak in the drain below the dash. I'll research further & if I find something useful I'll post. Sorry guy.
Jonahs
Old 04-03-2005, 08:29 PM
drain routing. This might help.
Jonahs
Old 04-03-2005, 08:30 PM
Dan Dan is offline
Here is the front drain hose schematic, if its any help to you.
Dan Dan is offline
Damn! You beat me by one minute with the pic!
Old 04-03-2005, 09:17 PM
Thanks guys...maybe I will snake the drains.
Does this make look right?
Old 04-03-2005, 09:19 PM
Thanks again for your help this far guys...it is suppose to rain all frickin week here.
Old 04-03-2005, 10:22 PM
Let us know how you make out. Lots of interest in H2 leaks!
Jonahs
Old 04-03-2005, 10:26 PM
ok, under the marker light is a hole that the wire goes down. It is not wet under the light per say...but there is water in the hole...weird. </div></BLOCKQUOTE>I missed this post. Are you saying when you pull the rubber boot off that the marker light wire goes through there's water in the hole below it??? If so, there certainly shouldn't be water there and that's the problem.
Jonahs
Old 04-03-2005, 10:48 PM
LV, yeah, I really was not deep into it on that earlier post...but see below:
I put RTV around the inside of the marker lamp gromet, and then stuck it back on...it was dry under it, so I do not think that is it. But, I will do the hose test after the RVT dries.
What else can cause a leak up there other than the marker light? Only the sunroof? I also looked under the dash...looks dry..I am pissed I cannot find it. It IS coming out from the metal under the kick plate.
Old 04-03-2005, 10:59 PM
oops
Old 04-03-2005, 11:00 PM
Well of course there's always the possibility of a windshield leak. Water can do strange things and many times it ends up in a place totally unrelated. From the roof down the only things I can think of is the clearance lights and the sunroof drains. There has been an ongoing problem with the sunroof drains kinking, even on the '05s. If that's it, for it to show up inside the kick panel it would almost have to be just below the A Pillar where the drain turns. The only other thing you might check is the rubber grommets between the body and the front of the doors. There's been reports of leaks at the door defroster & wiring grommets.
Jonahs
Old 04-03-2005, 11:05 PM
OK.
LV, thanks for all your help man! I will check those other locations tomorrow. My dealer is about 80 miles away...and I have not got the time to take time off right now for that. I feel like I can take care of this. Wonder if they would say the RTV will void my warranty.
