Old 02-01-2005, 04:35 PM
TroysH2 TroysH2 is offline
TroysH2 is off the scale
All electrical items work. Turn ignition, nothing (this does not effect/drain electrical using items).
Is this a common issue. I am going to run a hot lead to the starter to check it. Only other possibilities 1)ignition, 2)Fuse??? is this a common problem, 3)Starter and/or Starter coil.
Thanks for any suggestions!
Old 02-01-2005, 06:50 PM
Update:
Cross started(put a wrench between two of the posts on the starter solenoid) the starter solenoid. With ignition turned on this worked. Now H2 starts with no problem.
I know this is basic mechanics, but does this indicate a problem with the ignition or the starter solenoid.
thanks again for any suggestions!
Old 02-02-2005, 02:25 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
At the ignition switch check for power with a test light at the pink wire(ign 1 voltage) while attempting to crank if the test light does not light, or lights dim you are losing ign 1 voltage and will require A new ign switch, common problem I have changed out about 20 in the past year. Hope that helps.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 02-02-2005, 03:12 AM
LasVegas LasVegas is offline
LasVegas is off the scale
Hey HUMTECH. Sounds like you can answer this question. Check this product http://www.autoloc.com/detail.lasso?itemid=WC1000 I'm going to install it on the sunroof circuit for one touch open/close. They say it will work. It just goes inline on each open close circuit & when the appliance reaches its stop it senses the extra load and disconnect. I just want to be sure it won't screw with the Hummer module. Got an opinion?
Jonahs
Old 02-03-2005, 02:57 AM
HUMTECH's Avatar
Vegas, The link wont open for me but if you can post any info, schematics, or operation description i'll try to help ya out.
1998 Chev Z71
Old 02-03-2005, 03:14 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by HUMTECH:
Vegas, The link wont open for me but if you can post any info, schematics, or operation description i'll try to help ya out. <HR></BLOCKQUOTE>
Here's the schematic. It just has its own microprocessor that senses the load when the window/sunroof stops & then disconnects.
Jonahs
