01-21-2006, 02:50 AM
Ken - You going rack free on this truck?
\'05 SUT
01-21-2006, 03:11 AM
Yes, for now I am.
01-21-2006, 03:24 AM
I like the look (a lot) as is. Can't imagine adding even a few more inches to the height!
\'05 SUT
01-21-2006, 03:38 AM
You aren't kidding.
01-21-2006, 03:50 PM
Mount it to your ladder. </div></BLOCKQUOTE>
Not sure the door would open (on its own) with 40 lbs on there.
I'll probably just continue to use the 'bungie it to the rack' method until GOBI comes through.
I have the rubber handle keeper and like it. Keeps the metal separated.
01-30-2006, 12:30 AM
Damn, I missed this whole thread! Nice job Ken!!!!! Looks good.
01-30-2006, 12:34 AM
Thanks Tim.
01-30-2006, 03:09 AM
Any methods out there of mounting it on the OEM roof racks?
01-30-2006, 03:59 AM
Any methods out there of mounting it on the OEM roof racks? </div></BLOCKQUOTE>I haven't seen that, but it's probably because it's a PITA to get down and put up while you're on a trail.
However, if you want to do that here is how:
You MUST use a 13mm NUT, not threads, but wrench size, on the inside of the rack so it will fit snuggly in the underside grooves of the rack and not spin while tightening the bolt from above. You would need two of these to hold the jack in place.
Here's a pic of my CB antenna mount and you'll get a better understanding why this method is not a wise choice. Then you remove the bolt, the nut will fall, you'll have to pull the rack caps and.... PITA
Now if you used a bolt from the underside, you'd still need to find a way to hold it in place.
I've got it! Use a bolt with a wrench size of 13mm and 2" in length and run it UP through the rail and secure it with a nut and lock washer. Put your jack on top running the bolts through the holes and use a couple of wing nuts to hold it down.
Damn, that took me some time to get to, huh?
01-30-2006, 01:44 PM
Damn, I think I actually understood you
That's a good idea, thx Ken...
01-30-2006, 01:51 PM
That's a good idea, thx Ken... </div></BLOCKQUOTE>Yeah, ignore everything but this:
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content"> I've got it! Use a bolt with a wrench size of 13mm and 2" in length and run it UP through the rail and secure it with a nut and lock washer. Put your jack on top running the bolts through the holes and use a couple of wing nuts to hold it down. </div></BLOCKQUOTE>You will need to trim up the rubber on top of the rack.
01-30-2006, 03:12 PM
I've been unavoidably detained lately and missed this thread.
Ken, did you mark your holes on the Hi-Lift so that you don't have to guess which ones to line back up with the bolts?
I considered one of these Jack Guards if I were to do a rack or maybe try to make it work on the front or rear.
But, I'll probably have an X-Jack by our next trip to use instead of the Hi-lift. Besides I broke the little switch release thingy on mine.
01-30-2006, 03:24 PM
Rob (Ipedog - Say "Ip-E-Dog")
Black Sheep HUMMER Squadron
01-30-2006, 03:34 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Ipedog:
Don't try to go through an Airport with that!  </div></BLOCKQUOTE>Well, I could make some corny remark like "I don't think I'll be Hi-<STRIKE>lift</STRIKE>-jacking a plane anytime soon, so no worries" but I won't. It would probably cause me a visit by some suits.
01-30-2006, 04:35 PM
Ken, did you mark your holes on the Hi-Lift so that you don't have to guess which ones to line back up with the bolts? </div></BLOCKQUOTE>Just a shot of spray paint on all of it.  Very ghetto, but only the 4k members of this board know that.
01-30-2006, 06:02 PM
Is it possible to mount the jack lower so you don't have to do the wing nut thing????
01-30-2006, 06:11 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Mr. I - Man:
Is it possible to mount the jack lower so you don't have to do the wing nut thing???? </div></BLOCKQUOTE>
For an SUV yes. Take a look here at H2Finally's method: http://elcova.com/groupee/forums/a/t...68/r/818102768
With the SUT fold down gate, maybe. I'm guessing you have to mount it way off center so that when you swing the arm all the way open it leaves room for the gate to open. See Ken's fourth picture. It gives a pretty good idea of how much/little room there is between the vertical on the carrier and the gate. I wonder if you could tuck it under the gate just a little to keep it from being really off center. Ken?
'03 pewter base H2
