Old 02-09-2006, 02:12 PM
fourfourto's Avatar
I did not adjust torsion bars but I did buy a ventvisor sunroof deflector,it goes on with double sided tape(3m).It cuts wind noise down alot.
Old 02-09-2006, 02:29 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by fourfourto:
I did not adjust torsion bars but I did buy a ventvisor sunroof deflector,it goes on with double sided tape(3m).It cuts wind noise down alot. </div></BLOCKQUOTE>
Where did you get yours and how much?
Old 02-09-2006, 03:09 PM
Black H1 Black H1 is offline
Black H1 is an unknown quantity at this point
I had the dealer go 3/4" under level from the rear and realign the old girl. I have not noticed any wind noise, but I live in SD and the only time the wind stops is when it changes direction.
Old 02-09-2006, 03:14 PM
I have noticed that the truck does handle nicely off road raised up and the stance does look a little meaner. My pregnant wife complains every time she gets in, so I got that going for me too.
Old 02-09-2006, 04:00 PM
Thanks for the info. 3/4" lower than the back should be about right. I really don't like the look from the factory but I guess there is a reason for it. I will see if they will adjust it Monday. Did they do your alignment right then? Do you need to wait to let it settle in a bit?
Old 02-09-2006, 06:25 PM
humdoug's Avatar
humdoug humdoug is offline
humdoug is an unknown quantity at this point
I made the adjustment myself, lifted the front tires off the ground and turned the torsion bar bolts clockwise 2 1/2 times each. I waited for 100 miles before I had it aligned. One side was out a bit but not much.
GO FOR IT!!!!!!!!!!!!!!!!!!!!
Old 02-09-2006, 06:26 PM
Can anyone say for sure if this can potentially give the dealer a reason to decline any warranty claims?
Old 02-09-2006, 08:48 PM
Hummie3 Hummie3 is offline
Hummie3 is off the scale
Can anyone say for sure if this can potentially give the dealer a reason to decline any warranty claims? </div></BLOCKQUOTE>
If your not sure have the dealer adjust the torsion bars. Thats what I did.
2006 H3, Torsion bar tweek and 285/75r 16 Bridgestone REVO tires
Old 02-09-2006, 10:40 PM
humdoug's Avatar
I took mine to the dealer and told him I made the adjustment. I asked if it would become a warranty issue. I was told no. He also told me it looked GREAT.
Old 02-09-2006, 10:52 PM
fourfourto's Avatar
HummerNewbie
Posted Feb 9, 11:29 AM
Where did you get yours and how much ?
Pep boys has them under $50.00.They usually have to order the larger ones in.I forgot the part # just look at one of the smaller ones they have instock and theres a chart on it for part # and sizes. easy install and matches the window visors.
Old 02-10-2006, 12:57 AM
jp's-h3 jp's-h3 is offline
I made the adjustment myself (2.5 turns), did not tell the dealership when they alligned it, nor did they mention it! it looks much meaner, and drives nicely!
Old 02-10-2006, 01:01 PM
Pep boys has them under $50.00.They usually have to order the larger ones in.I forgot the part # just look at one of the smaller ones they have instock and theres a chart on it for part # and sizes. easy install and matches the window visors. </div></BLOCKQUOTE>
I might be going by a Pep Boys this weekend so will have to check it out thanks.
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by jp's-h3:
I made the adjustment myself (2.5 turns), did not tell the dealership when they alligned it, nor did they mention it! it looks much meaner, and drives nicely! </div></BLOCKQUOTE>
Good to know. I may go ahead and do it this weekend before dropping it off on Monday.
Old 02-12-2006, 03:41 AM
I highly recommend it, very easy and looks MEAN.
If your not going to lift it, it will also fit those 35's much better!
Old 02-13-2006, 01:31 PM
I raised it 2 turns this weekend and it looks great.
Old 02-16-2006, 11:19 PM
Here are a couple of pics after turning 2.5 times!
Old 02-16-2006, 11:22 PM
LET IT SNOW!
Old 02-17-2006, 01:10 PM
Asked them to do an alignment when it was in on Monday for the DVD/marker light install but they said they couldn't yet. Have to wait until it has at least 500 miles to do it. Oh well, have to take it back when the part they ordered for the sunroof comes in and will have 500 by the end of the weekend.
Old 02-19-2006, 06:38 PM
KJS KJS is offline
KJS is an unknown quantity at this point
I guess I suck at using the search here b/c I keep coming up short on pix. Can any of you please repost your before and after or any side-by-sides etc?
Old 02-20-2006, 05:18 PM
Kind of hard to really tell in these shot but here is a before and after.
Old 02-21-2006, 01:24 AM
NM H3's Avatar
NM H3 NM H3 is offline
NM H3 is off the scale
Just did mine 2.5 turns, and got about 1.5" of lift. Took all of 5 minutes. Looks much better.
