Old 03-01-2004, 08:32 PM
Skulz Skulz is offline
Skulz is off the scale
I'm looking for ideas/suggestions on where people have placed their antennas. Pictures are very welcome. I'm considering 2 antennas (one for CB and one for VHF), but don't let that prohibit you from posting if you only have one or the other. I'm not sure how far I should distance them or what to use for mounting. I'm tired of the magnetic ones getting knocked off by branches. I don't have a rear tire carrier either, so that may change my options.
Thanks for any input.
-Skulz
-Skulz
Old 03-02-2004, 02:11 AM
sigsauer sigsauer is offline
sigsauer is off the scale
Do a search for cb mounting and you will see good ideas. I did mine like Glenn and it has worked great. http://elcova.com/groupee/forums?q=Y&a=tpc&s=2826088551&f=6706011751&m=36860 44512&p=1
Old 03-02-2004, 01:22 PM
Thanks. Did a search on antenna yesterday and didn't come up with anything remotely close. I knew there had to be something somewhere.
Old 03-04-2004, 04:53 PM
It\'s a Dry Heat's Avatar
For the CB get a magnetic unless your driving an H1 soft top. You might put it on your front bumper and point it forward as you follow H2's, because we are high enough to see where we are going. H2 people put it any place you want it. We drive metal vehicles
04 Yel H2, F&R Eaton lockers, SMA HD brush guard, XD9000i, Garmin StreetPilot 3
Old 03-04-2004, 07:07 PM
SunsetShannon SunsetShannon is offline
SunsetShannon is off the scale
Skulz,
Where are you mounting your CB?
I found a great solution. Solid as a rock. I got it through RubberDuck 4x4. My pictures (on my personal website) don't do it justice... but it's a cheap option for an awesome CB mount! Let me know if you have any questions. I think R2 has the same set-up!
- Shannon
Indianapolis, IN
Sunset Orange H2
http://www.geocities.com/rottinmom/index.html
- Shannon
\'98 Black OpenTop H1
Former Sunset Orange H2
Viva la E.C.H.O.!
Old 03-05-2004, 04:54 PM
Shannon,
That looks like a great mount. Currently my cb is on an old mount setup to sit over a hump in an older car (if you can picture this). Two flaps that anchor it down on the hump. The flaps fold underneat, so I just have it all sitting on the "cd storage bin". I can then velcro the VHF radio on top of the CB. I'll have to look more at your setup though as that seems more practical. VHF is really small, so can always mount it underneath the steering wheel by right leg.
I have magnetic antennas for both the CB and the VHF, but I'm not sure how much distance needs to be inbetween the two. Branches tend to be on one side or the other on the trails, so I put my cb antenna in the middle (where it still gets knocked over a few times per day). Just recently got the VHF, so this is a new dilemma.
Thinking about the setup Phil has for a CB and then maybe just sticking with magnetic for VHF or vice versa.
Although now you have me drooling over extra underbody protection!
Old 03-05-2004, 05:38 PM
Ha, Ha, smart man The upgraded undercarriage protection is a MUST for offroading! PhilD has done the best write-up that I've seen...
RubberDuck 4x4 UCP
- Shannon
Indianapolis, IN
Sunset Orange H2
- Shannon
Viva la E.C.H.O.!
