Old 08-15-2005, 12:05 AM
redbulljunkie67 redbulljunkie67 is offline
redbulljunkie67 is off the scale
What changes need to be made to an '04 SUV for a stock'05 swing-away spare tire holder with the center lic plate holder?
Thanks in advance!
Thanks in advance!
Old 08-15-2005, 01:41 AM
sclui56 sclui56 is offline
sclui56 is off the scale
Try this for starters:
http://elcova.com/groupee/forums/a/tpc/f/6706011751/m/5.../190102839#190102839
Old 08-15-2005, 02:12 AM
Thanks sclui56 That answered tons of the questions I had!!!
Old 08-15-2005, 03:14 AM
Red,
Just thought I would mention that the 1/4" reinforcement for the 5th hole can be had at most hardware stores, 2x2" square, already has hole in center.
Old 08-15-2005, 11:06 AM
I have a couple galvanized 2"x2" squares left over from a deck I built with 1/4 " holes I was going to try one of those.
Old 08-15-2005, 05:47 PM
greenhummer greenhummer is offline
greenhummer is off the scale
So, are the '05s suppose to have this 2" X 2" plate behind the rightmost hole on the right mounting bracket for the wheel holder?
Took my brackets off a while back and did not come across any plate. Just a fairly hefty washer.
thanks,
Greenhummer - '05 H2 SUV Lux/'00 BMW M5
Old 08-15-2005, 05:57 PM
Hummertech is off the scale
To save some money, I would try to see if you could find someone near you that has the factory rear mounted spare tire, and see if they would like to trade. Many people do not like the rear mounted spare tire.
Old 08-15-2005, 06:39 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by greenhummer:
thanks,
Greenhummer - '05 H2 SUV Lux/'00 BMW M5 </div></BLOCKQUOTE>
Probably it has a non-removable threaded piece on the inside like the other 4 holes. It is only needed for the ones not equipped for the tire carrier as the rear bumper material is much thinner than the front.
Old 08-15-2005, 07:13 PM
I read the install that sclui56 did and it was easy (great instructions and photos)if I would have bought the bumper that was made for the tire holder I would not had to do any mods.drilling a hole and backing up the area with a 2"x"2 plate saved me around $150.00.I guess if I ever change my mind I can get a plastic plug for the hole...
Hummertech, I get my H2 serviced at Sewell in Dallas..whats your first name?
Old 08-15-2005, 07:29 PM
red, I believe there's more to it than just the bumper, the L&R braces are also different, and possibly the L&R end caps, so it wasn't just the hole.
I recall checking that out before I went the cheaper route.
Old 08-15-2005, 08:32 PM
If you live in NRH, then why do you drive to Sewell in Dallas, wouldn't the Sewell Hummer in Plano be much closer? My name is John
Old 08-16-2005, 02:03 AM
good point sclui56.
Hummertech I live east of dfw airport close to Precinct Line and 26.Classic Hummer is realy close about 5 miles(but they are not as helpful)Sewell Dallas is alot closer to me than Plano.
