05-19-2006, 05:56 PM
Tire Size
Just installed some 37" BFG All-Terrains... for giggles I put a measuring tape on them... the height actually measures 35" -- barely. How the heck do tire manufacturers calculate their measurements... I neved did check the actual tire size of my old 35"s. Just curious...
May your glass be ever full.
May the roof over your head be always strong.
And may you be in heaven half an hour before the devil knows you're dead. ~ Irish Blessing
05-19-2006, 07:02 PM
Re: Tire Size
Are you measuring the ones supporting the vehicle? If so, the bottom of the tire is deformed.
05-19-2006, 07:35 PM
Re: Tire Size
I want to go with 37"s also but was told the fronts might rub? is this true?.....do you have any pictures?
05-19-2006, 08:23 PM
Re: Tire Size
37"x13.5" Cooper STTs.
05-19-2006, 10:15 PM
Re: Tire Size
They'll rub just a little as you can see in hawk's pic. Nothing to worry about.
05-20-2006, 05:00 AM
Re: Tire Size
My 35's rubbed in that spot before I got the weld rims.
05-20-2006, 02:46 PM
Re: Tire Size
It depends on your alignment. When I first got my 37s on, no rub at all. A dealer alignment screwed it up tho.
Stacy
05-20-2006, 03:23 PM
Re: Tire Size
Can someone post a picture (full view) with 37s on there truck...
05-20-2006, 04:03 PM
Re: Tire Size
Your sway bar can slightly move from side to side as well
05-20-2006, 07:29 PM
Re: Tire Size
my 37x13.50 nittos rubbed than i cranked the torsion bars and used a heat gun to push the fender liner back a little and it hrdly touches at all now, i was told the torsion crank would cause premature wear on the steering components but fukk it
05-21-2006, 03:27 AM
Re: Tire Size
Mt stock tires rub there too.
05-21-2006, 05:05 PM
Re: Tire Size
Here ya go - no lift.
Stacy
05-22-2006, 05:54 PM
Re: Tire Size
Originally Posted by PhilD
Several factors will effect actual height, mainly; the weight of the vehicle, the tire pressure and rim width. Manufacturers will measure the tire without any load on it, sometimes at max psi and the height will be for a specific rim width. Add a load, lower the psi, and/or use a different rim width and your measured height will be different.
My 38's only measure 36.75" when on the vehicle.
Phil -- THAT was the help I was looking for. I figured that pressure, load weight, rim size, etc. would account for various standing sizes. Appreciate your help. The rack and ladder look fantastic -- thanks! Rancho lift went on great... I'll submit pics ASAP.
