Old 07-31-2006, 09:46 PM
RobsNVRL8 RobsNVRL8 is offline
RobsNVRL8 is on a distinguished road
Default Question re: seat memory setting in 2006 H2
I just purchased a 2006 H2. I've been trying to set the seat to user 1, and have an exit position for it also. The problem I am having is that when I put the key in the ignition, the seat doesnt move forward unless i press the seat one button on the door. It does however move to the exit position when I take the key out. The sales person said I must be setting it incorrecty. Is the seat supposed to move to the preset position when i put the key in the ignition (with using remote 1), or am I to push the button each time I enter the vehicle?
thanks for you help
Old 07-31-2006, 10:04 PM
tomp's Avatar
tomp tomp is offline
Default Re: Question re: seat memory setting in 2006 H2
Not sure how the remote works...
I push the button each time I get in.
Old 07-31-2006, 10:15 PM
Rob, you are a little late.
They don't do that anymore. You have to push the preset. Back on '03s and, I'm not sure about '04s, it does work and it also works off the key fob. You have fob 1 and fob 2 so it knows which preset to go to.
Old 07-31-2006, 10:38 PM
seems odd that they wouldnt match the remote to the seat setting. thanks for the reply guys
Old 08-01-2006, 01:52 AM
Bajabum's Avatar
Bajabum Bajabum is offline
Bajabum is on a distinguished road
Rob,
I have an 04. When I unlock the car with the key fob it resets the seat to my preset. If I make any adjustments when driving and I dont set the button on the door it will go back again to my preset when I unlock again. Mine doesn't do anything when I put the key in the ignition. Hope that helps. Congrats on your new baby
Old 08-01-2006, 06:47 AM
Jeff B's Avatar
Jeff B Jeff B is offline
Jeff B is off the scale
In my 04 I have the option to turn that feature on and off for each user from the steering wheel controls.
Old 08-01-2006, 06:24 PM
mwrbunny mwrbunny is offline
mwrbunny is on a distinguished road
X2
I have an '06 and you can activate the seat to adjust when you put your ignition key in. You have to use the steering wheel controls to scroll through the on-board computer settings & set it. Your computer will then recognize your key fob when you insert the key.
I know it's a last resort, but check out your owners manual
Old 08-04-2006, 11:57 PM
Originally Posted by mwrbunny
X2
I did check the manual, I even called the dealer and asked them. They said it doesnt adjust back to the driver position after using the exit setting. crazy i know. I went thru all the items on the computer menu. ive settled down about it now but damn was i disappointed to find that my friends avalanche does it for both key fobs.
Old 08-05-2006, 12:13 AM
Vettster Vettster is offline
X2
I also have an 06 and cannot get it to do this either.
Hmmm......
Update: I checked again and it will only allow the seat to move upon removing the key.
