08-26-2006, 10:15 PM
engine light on
the other day i took my H2 to get washed after it was done i turned it on and it made noise like it was out of gas, even though it had about a quarter of gas.Either way i put more gas in it. 2 hours later the engine light turned on. anyone else have this problem or might know whats going on
08-26-2006, 11:49 PM
Re: engine light on
Did you wash the engine also?? Maybe you got a coil wet or something. My engine light is on all the time , to many sensors .I need to get it looked at. My service rear suspension light has been flashing for a year . When the rear suspension craps out i just disconnect the battery and reset it.
Also , i want to rat this thing out to give people something to really talk about instead of what i get for mileage. Can anyone photoshop a set of longhorns on the hood of my H2 if i post a pic of it. doug
08-26-2006, 11:52 PM
Re: engine light on
Heres a pic. of the front end. I would like a big set of longhorn cattle horns on front.
Thanks , Doug
08-27-2006, 03:16 AM
Re: engine light on
what?
66' VETTE STINGRAY
07' Z06
08-27-2006, 07:17 PM
Re: engine light on
check your intake tube into the manifold? Probably is loose causing a lean gas code, setting off the check engine light.
08-27-2006, 08:18 PM
Re: engine light on
doug
08-27-2006, 10:25 PM
Re: engine light on
Also does anyone know how to reset the computer cause that might turn the light off if something really isnt wrong with it.
08-28-2006, 12:20 AM
Re: engine light on
I'm not sure how to reset the computer. BUt disconnecting the battery and hooking it back up might reset some of the electrical codes. doug
08-28-2006, 01:45 AM
Re: engine light on
buy a code reader, see what the code is, and then you can reset it with the code reader machine.
08-28-2006, 10:48 AM
Re: engine light on
Usually, the light goes out automatically if the fault is gone, except for some emissions and hard codes. After a specific number of engine cycles (cold engine to hot engine back to cold engine), the code is completely erased in the PCM/BCM memory. (Not true for a few airbag codes).
08-28-2006, 08:01 PM
Re: engine light on
Many of the auto parts stores can/will read the codes for you and even reset the ones they can. Be sure to make it worth his time.
mowdoc
2006 H2 Adventurer loaded named "Wolfey Boy" - Pewter Silver/Wheat - Denali wood dash panels - SIR-GM1 Sirius
Wifey's ride is a 2007 Corvette 3LT F55 A6 named "Lucy"
2001 Jeep TJ with heavy mods is my off-roader - the Hummer stays clean
