09-27-2006, 12:10 AM
Re: Front Differential AND Driveline
and i will raise you one rear axle shaft
09-27-2006, 12:11 AM
09-27-2006, 12:28 AM
who broke the rear axle shaft?
Looks like it got magnetized
Was that on an H3?
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
09-27-2006, 12:38 AM
To strengthen the LS1 f-body rear ends when going to 4.11's many of us used the ratech solid pinion to replace the crush collar and a diff cover with bearing supports. The problem we saw was that after a few hard launches the crush collar would compress creating slop in the pinion and eventual failure.
The H3's 4.56 ratio pinions are pretty small and there is a large lateral force created especially when in the adv low range. Couple this with some slip-and-grips and the loads get pretty high. Not sure if the ratech solid spacer and diff cover would help with the H3.
i took that out back in april , i had to out do the beebster  the 7 hour tow off the mountain ate the end up like a pencil sharpener and magnitized it , kinda looked like a porcupine  . i kept trying to get up the stairs after the front ring gear went
09-27-2006, 05:26 PM
Is there an 8" or 8.25 front carrier that would work on the H3?
Even is slight modifications are necessary, that would still be better than the 7.25?
09-27-2006, 05:32 PM
Dana 60's front and rear?
I wish
Desert Dan
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
09-27-2006, 05:41 PM
HAHAHAHAHA
Does Dana make a Cast Iron IFS carrier???
09-28-2006, 06:31 AM
OK here is a pic of the latest carnage:
09-28-2006, 06:34 AM
ouch that not good pinion looks awful  and it drove home fine after Colorado ???????????
09-28-2006, 06:53 AM
It drove home fine, but when I got back I took it in a few days later cause it was making a loud clank when I put it into drive. That's when they changed the Carrier mount/bracket bushings. (Drivline forcing differential up is bad:-)
Then I picked it up and on the way to Deer Valley, I noticed when I got off the gas I would hear a "jingle bells" type sound. Sorta. It got worse and louder over the last couple of weeks, so I took it in and this is what they found. Caput!
This time they just changed the entire case and driveline.
I begged them to make sure I received a new "hardend gear" if possible.
They are also considering (99%) to extend the warranty on the front end (diff) to 100K. I'll know the final outcome of that on Friday.
Once again, HUMMER of Sacramento ROCKS!
