Old 10-16-2006, 05:42 AM
DoubleAction's Avatar
DoubleAction DoubleAction is offline
DoubleAction is on a distinguished road
Exclamation Torsion Bar Question?
Hi every one , i'm reading alot about the torsion bar adjustment so could someone post some pic's to show were is the torsion bar located and how to do the lifting thing..
Thanks 4 Reading
- HUMMER H3 Lux/Pkg (Boulder Gray) 2006
- Audi Q7 (White) 2009
Old 10-16-2006, 02:29 PM
H3.007 H3.007 is offline
Default Re: Torsion Bar Question?
IMHO - have a garage that specializes in computerized alignments do they job. Mine had to be adjusted at all four corners due to what the garage said was a crappy factory alignment (nope - no charge for the latter either, only the torsion bar adjustment).
Regardless, there are many posts here that already show the adjustment. Do a search for "torsion bars" and it should lead you to the requested information.
Old 10-16-2006, 11:45 PM
Thanx H3.007 for the info
Old 10-17-2006, 02:43 AM
My pleasure
BTW - the adjustment only set me back $50.
Old 10-17-2006, 04:18 AM
westhillsat's Avatar
Originally Posted by H3.007
My pleasure
The tire place that did mine charged $10 for the torsion turning and $40 for the alignment - so we spent the same
Old 10-17-2006, 04:24 AM
DaddyKiwi DaddyKiwi is offline
DaddyKiwi is on a distinguished road
You can turn the torsion bars VERY easily---and it is FREE--then if you have under 12K miles, the dealer service will align it for FREE!!!
The front bar adjustments are located roughly under the divider between the front and rear doors--it is a bolt that is 1 1/8th inch. Measure from ground to bottom of fender BEFORE turning, then jack it up, turn CLOCKWISE the number of turns you want, then set down--remeasure.
I turned my Drivers front 3.5 turns and the passenger Front 2.5 turns and it looks REAL good now--drives the same and all--I am taking it in for alignment later in the week and for some other minor things. Took all of 20 minutes.
Old 10-17-2006, 04:41 AM
My dealer is 3 1/2 hours away one way...
Old 10-18-2006, 01:18 AM
SDH3 SDH3 is offline
SDH3 is off the scale
What's your opinion of the ride since adjusting?
Old 10-19-2006, 02:35 PM
A lot less front end sway in curves; otherwise, no difference.
Old 10-21-2006, 08:06 PM
H3PAC's Avatar
H3PAC H3PAC is offline
I already have a fairly stiff ride on the road with the off-road package. Does this adjustment make the ride even stiffer?
(stiffer IS almost always better in most situations)
Old 10-21-2006, 09:55 PM
lotus4s's Avatar
lotus4s lotus4s is offline
I have the off-road pkg also and didn't notice much difference at all in the ride with 3 turns.
