Old 03-10-2007, 01:22 AM
Darren Darren is offline
Darren is off the scale
Default Anyone taken sunroof deflector off??..Noise??
Guys,
My Sunroof wind deflector is fouling the underside of the light bar (which is mounted as far forward as I can get it) and it's now started rattling really bad.
Has anyone simply removed the deflector part (the semi-clear smoked perspex part)??
If so did it give any issues with wind noise with the sunroof closed? (I know it will be noisier with it open - but that is not often the case!)
Thanks!
Old 03-10-2007, 02:23 AM
Default Re: Anyone taken sunroof deflector off??..Noise??
i took mine off when i installed my gobi rack and their isnt really any difference when the sunroof is closed but when open their is more wind noise.. but i also have lights up their. and now i have the gobi fairing.which helps.. but i would say its not a big deal when you close the sunroof.
Old 03-10-2007, 04:46 AM
MSeeb MSeeb is offline
MSeeb is off the scale
I ended up installing 4 pieces of two sided tape between the deflector and the light bar, which basically sticks them together. It's been in place for about a year and a half and no more noise. Cheap fix.
