Old 04-04-2007, 10:23 PM
Texas Red's Avatar
Texas Red is off the scale
Question Wet Floor board
I have a wet floor board on the driver's side. It's not coolant and not a rain leak. Could it be condensate from the A/C??
Jim
2008 H3 Graphite Lux
Old 04-04-2007, 10:29 PM
Hummer Aficionado_VT's Avatar
Default Re: Wet Floor board
You didn't spill a Big Gulp did you?
Old 04-04-2007, 10:50 PM
Texas Red's Avatar
It's not Coke, beer, or urine either. :-)
Jim
Old 04-04-2007, 10:51 PM
Your marker lights are leaking!!! OR
There is a drain hole/ hose form the upper chanel that gets plugged also.
It runs down your A pillar.
This was an issue on quite a few of the 03/04's. I also had this issue on my SUT and it was in fact that drain hose.
Old 04-04-2007, 10:58 PM
I bet you it was your washing machine.
Old 04-04-2007, 11:09 PM
Texas Red's Avatar
It's also wet on the side carpet where it goes up to the center console -- if that sheds any light. I will probably take it in to the dealer in the next day or two. I was hoping to give them a clue if I get that blank stare like a calf looking at a new gate.
Jim
Old 04-04-2007, 11:34 PM
NU-UH!!
It was a Big Gulp!!
Old 04-04-2007, 11:38 PM
IT'S THE HOSE
Old 04-05-2007, 12:49 AM
Red, you can try this:
Remove the front, driver's side marker light and make sure the gasket is firmly in place. Then squeeze out BLACK RTV all around the gasket. Don't worry if it puddles. Let it dry for a few hours and stick a water hose up there and let it run. Then check.
You can even pull the A-pillar cover off to see in there.
9 times out of 10, this is the problem.
Should take less than 5 minutes to do the repair.
That will narrow it down to the hose if it doesn't leak from there.
Old 04-05-2007, 02:02 AM
mikejr's Avatar
mikejr mikejr is offline
i concur with the hose being the cause. Had that issue in my avalanche with the hose that drains the sunroof....
2009 H2 Silver Ice LE
Old 04-05-2007, 05:52 AM
tazhog54's Avatar
tazhog54 tazhog54 is offline
tazhog54 is on a distinguished road
Take a air hose and blow some air threw the drain in the sun roof about 30lbs,pressure that way you will not blow the tube off and listen for air leaks !!
Put on turn signal count to ten and turn SPLAT!!Goes another tree hugger
03 H2 Sunburst orange
04 Corvette Silver(wifey's)
32 roadster Viperblue (SOLD)
32 3 window coupe COPPER ( almost done )
32 3 Window Coupe full fenders
32 Roadster
62 Nova SS
69 Chev p/u 427
72 Chev p/u ORANGE
34 Phanton (underconstruction)
34 5 window coupe Teal (SOLD)
95 Harley geiser glide red
74 Sportster {wifey's)Candy red w/flames
96 Harley Turbo charged
Old 04-05-2007, 12:35 PM
Texas Red's Avatar
Thanks for the input, guys. Although I don't have a sunroof.
I'll let you know what I find.
Jim
Old 04-06-2007, 02:51 AM
mikejr's Avatar
well there goes the leaky drain hose theory.....
Old 04-06-2007, 05:01 AM
Hummer Guy's Avatar
Hummer Guy is off the scale
hmmmm...is it possible i saw this truck w/ the fans running on it today?
-Brian
http://www.hummerguy.net
Old 04-06-2007, 02:38 PM
Ding, ding, ding... I'm the winner!!!!
Old 04-10-2007, 05:15 PM
Texas Red's Avatar
The dealer service dept. determined it was the front middle marker lights that were leaking. They said they verified before and after in the carwash. They assured me the larger marker lights on each end were OK.
We'll see. :-)
Jim
Old 04-10-2007, 08:50 PM
We'll see. :-)
Well hell, I was close enough.
