Old 08-03-2007, 02:46 AM
redbird redbird is offline
redbird is on a distinguished road
Default Transfer Case Question
Maybe a dumb question
If I jack up both rear wheels, and leave transfer case in 4 wheel high(not locked) Will the front axle pull vehicle or will rear tires simply spin?
Old 08-03-2007, 03:23 AM
tomp's Avatar
tomp tomp is offline
Default Re: Transfer Case Question
Front will pull
Old 08-03-2007, 01:57 PM
Both rear tires spin but vehicle will not move unless I lock the transfer case
so I guess there is a problem inside transfer case? Thanks
Old 08-03-2007, 02:22 PM
in 4 hi unlocked you should be getting 60% power to the rear and 40% to the front . t-case might be fine try getting all four wheels off the ground or find some sand and try getting half stuck and see if front tires will spin too . also try 4 hi-locked , that splits the power 50-50 front and rear , might be that your getting power to the rear before the front because more power is delivered to the rear axle in hi-unlock . good luck
Old 08-03-2007, 03:08 PM
tomp's Avatar
I have done this in the 2 and it pulls. I would think the 3 would do the same thing even 4-Hi unlocked
Old 08-03-2007, 07:42 PM
I don't understand why?
Old 08-03-2007, 08:33 PM
marin8703's Avatar
maybe your doing something wrong. btw why and how are you testing this out?
Old 08-03-2007, 10:19 PM
Vehicle locked up at highway speed, slid front tires down to about 15 mph
at that point tires unlocked. It was probably brakes applied via the Stabiltrak
however I am trying to check everything.
One more thing. If I block front tires against something solid and force the rear to spin, I hear a clicking noise from lower part of dash around the steering column and the traction light flashes. The same sound occured when I had the brakes lockup and slide. Any help is appreciated
Old 08-04-2007, 01:01 AM
Sounds like the TCS/Stabilitrak issues others have been having. Caused by bad sensor(s). Get it in to the dealer.
Old 08-04-2007, 01:21 AM
marin8703's Avatar
, sounds like it. but just the front tires locked up, thats weird. good luck
