Old 09-30-2007, 06:41 PM
dallas007 dallas007 is offline
dallas007 is on a distinguished road
Default Time for a new battery???
I have a 2004 H2 w/ 27,000 miles. That makes my battery almost 5 years old. So my question is while I have no indication of any problems now, is it smarter to replace it now while I can do it in my garage vs. finding it dead while I am sitting in the middle of the desert. I hate to toss a perfectly good battery away. Any suggestions??
Old 09-30-2007, 09:45 PM
KingVinnie's Avatar
KingVinnie KingVinnie is offline
KingVinnie is on a distinguished road
Default Re: Time for a new battery???
If you want to be safe, then yes 5 years you got your moneys worth out of it. On the other hand it could last 8 years who knows. Safe or Sorry??? If I were goning to the desert I have a nice fresh yellow top.
Old 09-30-2007, 09:47 PM
mikejr's Avatar
mikejr mikejr is offline
I agree....you got way more use out of the battery than expected. could last another couple of years or could die tomorrow. The cost of a battery is cheaper than the cost of a tow...
2009 H2 Silver Ice LE
Old 10-01-2007, 02:21 AM
what size yellow top fits in the h2 ? thanks
Old 10-01-2007, 02:34 AM
Hucky Hucky is offline
http://www.thelapd.com/Merchant2/mer...&Store_Code=H2
Old 10-01-2007, 05:50 PM
TXSUT's Avatar
TXSUT TXSUT is offline
http://www.elcovaforums.com/forums/s...ghlight=optima
Old 10-01-2007, 06:18 PM
Desert Dan's Avatar
A new battery after 5-years is a pretty good investment.
I'd rather replace in in my driveway on my terms than be stranded in the boonies.
Go for an Optima.
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 10-02-2007, 12:18 AM
IRA51's Avatar
IRA51 IRA51 is offline
There is no optima that will fit and give you the 880 cca the H2 requires,the group 79 is the proper battery for your H2. an optima side post will fit ,but will not have 880 cca . it will work just fine but is not the correct aplication . you got lucky for the first battery to last more than 4 years.
A government big enough to
you have.
-- Thomas Jefferson
Old 10-02-2007, 03:09 AM
I looked at the Optima's today and they tell me the red top will fit but you suggest the yellow top. As mentioned, the CCA's seem to be light on these batteries and only have a one year warranty. I wonder if they are big enough.
Old 10-02-2007, 04:25 AM
tower's Avatar
tower tower is offline
Yellow top 900cca @ 0F
o battery. Check for physical fit.
Old 10-02-2007, 06:36 PM
410225 410225 is offline
410225 is on a distinguished road
Part Number: 8014-045
YellowTop?; Deep Cycle Battery; Group D34/78; Cold Crank Amps 750; Crank Amps 870; Res. Capacity 120; Ampere Hour 55; Top Terminal; L-10 in.; W-6 7/8 in.; H-7 13/16 in.; UNBOXED;
Directly from the Optima site.
http://www.optimabatteries.com/off_r...d_your_optima/
Originally Posted by tower
Yellow top 900cca @ 0Fo battery. Check for physical fit.
Old 10-02-2007, 07:01 PM
dkhummerh2's Avatar
dkhummerh2 dkhummerh2 is offline
dkhummerh2 is on a distinguished road
i agree that you need to replace your battery, but you can save the old one for a future emergency use, wouldn't take it in on the $10 core. I would replace with a oem battery if the other lasted 5 years. Optima is a very good brand, but do you need it? I would replace with an oem and hope to get another 5 years.
dk
Darin Kaiser
Old 10-02-2007, 07:03 PM
IRA51's Avatar
GROUP 79
you have.
-- Thomas Jefferson
Old 10-05-2007, 04:37 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Cheaper to keep A set of booster cables on board. A dead battery will not kill your truck unless you shut it down. Usually Someone will be around to boost ya and off to the parts store ya go. Keep A 8mm wrench, 13mm socket, 4" extension and 3/8" drive ratchet and you have all the tools once you get to the parts store. I had A customer ask me to change his battery out at 6 yrs and he didn't want the old one, it lasted another 4 in my jeep. On the other hand I have seen them fail after less than A year.
Old 10-05-2007, 05:47 AM
tower's Avatar
LINK
Old 10-05-2007, 06:35 PM
IRA51's Avatar
And it still has NO side post conectors. if you want to modify your cables than it may work if the posts on top clear your hood . or just slide in a good 7 year group 79 and call it a day.
you have.
-- Thomas Jefferson
