Old 10-08-2007, 10:15 AM
Hoppy111 Hoppy111 is offline
Hoppy111 is on a distinguished road
Default H3 and 15 inch rims
Hi there guy's, I was wondering if H3's can take 15 in rims and can a 35inch tyre fit the stock suspension
Cheers
Hoppy
Old 10-08-2007, 12:41 PM
3Hummer's Avatar
3Hummer 3Hummer is offline
Default Re: H3 and 15 inch rims
why wouldnt you just stick with the stock rims? as for 35 inch tires on the stock suspension, lots of people on here have it.
2017 VW Jetta S
2012 Cessna 182T Skylane
/''T''|[___|___]
[---T--L -OlllllllO-]
()_)"""()_)/"**"\)_)
Old 10-09-2007, 10:25 PM
Steve #1 Steve #1 is offline
Steve #1 is on a distinguished road
I don't think 15s will fit. There's hardly any space between the front calipers and the inside of the rim with 16s.
Old 10-09-2007, 10:37 PM
stagger_lee's Avatar
Nope. I measured you will have about 3/16" between rim and caliper with a 15" rim. Not enough for proper cooling or clearence for any little rocks that might try to jam in there. Technically they fit, but not safely.
White Collar Hippie
'06 Luxury Adventure
'99 Toyota 4runner 4x4
'71 FJ40
Old 10-10-2007, 09:50 PM
wannabeH3's Avatar
wont fit the brakes barely clear the 16s as it is
(with insurance)
Old 10-11-2007, 01:42 PM
Thanks for you reply's, I am looking at buying a H3 and I have some new 35 Mickey Thompson MTZ's in 15inch in the shed, so I was wondering if they would fit.
HOPPY
Old 10-11-2007, 09:49 PM
I wish man, I was in the same boat. I have a set of fairly new 35" BFG MTs on 15" Eagle alloys. First thing I did when I got the H3 was try to stuff those bad boys on there. no work.
White Collar Hippie
'71 FJ40
Old 10-11-2007, 10:13 PM
D-MAX's Avatar
D-MAX D-MAX is offline
D-MAX is on a distinguished road
have you tried using spacers or adapters? i had to do that to my GMC 2500 when i put h2 wheels on it. looks good and no problems @ 10k miles so far.
2007 h3x
2006 GMC 2500HD DURAMAX
Old 10-11-2007, 10:25 PM
Probably would have to space out about 2-3"s if I remember correctly based on the eagles I have. That would push the tire way out, probably causing premature wear on wheel bearings, huh? Would look pretty cool though. CAli law would require me to have mudd flaps in that case though...ghey.
White Collar Hippie
'71 FJ40
