03-07-2006, 01:15 AM
where should i go? im thinking 38, will that require a gear swap for mostly highway driving? thanks
03-07-2006, 01:42 AM
I'm a 3 inch rockstar, if that helps.
03-07-2006, 05:14 AM
HUH?
03-07-2006, 05:32 AM
That's a generous estimate.
03-07-2006, 05:41 AM
Originally posted by H2 Rocks:
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by mplv:
HUH? </div></BLOCKQUOTE>Nothing
03-08-2006, 12:14 AM
lets try again. i want to buy some 22 inch kmc rockstars with 38 inch tires. who has the best deal on them. i also need to know if this will require a gear swap. thanks
03-08-2006, 12:18 AM
Good luck on those tires fitting without a lift.
03-08-2006, 12:38 AM
I put on 41s without a lift. NO problem.
03-08-2006, 12:39 AM
Of course..I can only drive straight. But it looks COOOOOL.
03-08-2006, 01:25 AM
i was planning on a 6 inch fabtech but not right away, if 38s wont work without a lift what will?
03-08-2006, 01:42 AM
Geez...That's too bad
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
03-08-2006, 02:15 AM
dont listen to any of these pricks, u can squeeze 37x13.50 r18 on, thats what i did- i cranked the torsion bars up all the way i just did it today as a matter of fact, before that they rubbed pretty bad on the right side and use a heat gun to push the wheel liners away from the tires they still rub a tiny bit but not anywhere near as bad as before, for 38 u most certainly need a lift and a 6inch fabtech is the best bet, if i ever lift i will definately do the gear thing and prolly supercahrge as well , but that is a dream right now, there are plenty of guys who run the lift with 38 in tires w/ no gear difference as for the best place to buy , just do a saerch bro
03-08-2006, 02:23 AM
STFU. Don't be giving out any advice until you've earned some credit around here. Cranking the torsion bars all the way up is only asking for front drivetrain bind, so please report back to us in about 6 months when you are replacing your halfshafts or CVs or front driveshaft.
Forcing something that doesn't fit is just stupid. I have 37x12.5x17 and they rub on the sway bar and the frame. More rub and you will be binding the tires up and tearing up the steering, for what, to be a dumbass.
Dickhead.
03-08-2006, 03:16 AM
37 will work without a lift
I think you should do the lift first... I have 22 inch RS with 40 inch tires... The rims were like 500 and the tires 850
03-08-2006, 04:50 AM
Originally posted by MONSTERMATT*:
hey don't call me gay just because Ive screwd some guys over her by not gettin stuff I said i would, you al suk anyway and i don't need to listen to you because im better than you bro.
You're an idiot.
03-08-2006, 10:32 AM
damn 850 for tires is nuts, my rear viper tires cost that for a pair. of course they only last 5k miles but i may have had something to do with that.
how much more are the 40s than the 37s and what width can i go with?
03-08-2006, 10:33 AM
by the way albie your truck is SICK.
03-08-2006, 01:11 PM
oh that last post is pretty funny considering i didnt submit it and one of you losers did under my screen name
