Old 05-01-2006, 10:12 PM
2-H2's's Avatar
2-H2's 2-H2's is offline
Ron Carter in Friendswood, Texas
Old 05-01-2006, 10:13 PM
Originally posted by 2-H2's:
It appears that a ground wire had worked itself loose under the steering wheel. There are three plugs in a cluster, the center one was the one causing the headaches. Once the wire was attached properly & the computer reset...walla...four wheel driving again!!!
I'll have to say the dealer was very courteous today & handled everything to my satisfaction. And yes it was covered under the warranty. Yee-Haw
LC
That would be the Transfer Case Shift Control Module. 3 plugs going into it and a very good place to check if you get the dreaded <STRIKE>4wd</STRIKE> light
Old 05-01-2006, 10:20 PM
2-H2's's Avatar
Originally posted by PARAGON:
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by 2-H2's:
LC
That would be the Transfer Case Shift Control Module. 3 plugs going into it and a very good place to check if you get the dreaded <STRIKE>4wd</STRIKE> light </div></BLOCKQUOTE>
I don't feel so stupid about not finding it now. It only took the technician from 9:15 AM until 1:00 PM with all of his manuals & computer help.
Damn & now I've missed out on the immagration thingy downtown...
LC
Old 05-01-2006, 10:24 PM
2-H2's's Avatar
Paragon,
What's wrong...Alec will not play with you? So now I'm the prey Thanks for the help & information.
LC
Old 05-01-2006, 10:38 PM
Paragon,
LC
Now we all know of a place to go wiggle some wires first if it happens again. Of course, I would just press F5 to fix mine.
And who's Alec?
