Old 04-08-2004, 07:55 PM
H2_SUT_SC H2_SUT_SC is offline
H2_SUT_SC is off the scale
I had planned on getting 325/60R20's (Nitto Terra Grapplers) on a 20x11" wide rim. I've seen this set up on an H2 and I think it looks almost perfect w/o a lift as the tires stick out more than usual and he has no problem with rubbing.
Now here's my question. I've seen that some of you guys run the 37x12.5 BFG or MTR's w/o rubbing as well. I just came across this tire from Toyo that is 355/60R20. So it's essentially a tad taller and wider than the 305/60.
I checked out the specs of each one and I'll list them below.
37x12.50R17 - 36.8" tall - 12.5" wide
305/60R20 - 35.2" tall - 12.9" wide
355/60R20 - 36.8" tall - 14.2" wide
So it appears that the 355/60 is the same height as the 37" but about 1-1/2" wider.
Anyone want to guess if this will fit w/o a lift?
If I have to lift it I'd go with 38's or 40's as I prefer the full wheel well look.
Old 04-08-2004, 07:57 PM
Here's a pic of the 325/60R20 on a 20x11" rim.
Old 04-08-2004, 07:59 PM
belezeebub belezeebub is offline
belezeebub is off the scale
Not sure about fit but depending on the back spacing on the rim it may still rub, it really depends on the rims you choose I have even seen the WRONG rims on trucks and they hit the inner fender well in tight turns.
I ran 285x85x16 and 265x75x16 on a unlifted 3/4 ton Surburban with no rubbing so its possible.
“Slow response”
You must be imagining it,
Your port is routed Via a Net Optics Net1000SX to a Finisar Multi-Mode GBIC, from there your packets Travel over a 850Nm Laser connection to our High speed 7800KB/sec Max Optical Storage device, I see
Old 04-08-2004, 08:00 PM
Nice, do you loose any ground clearance on that set up?
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by H2_SUT_SC:
Here's a pic of the 325/60R20 on a 20x11" rim. <HR></BLOCKQUOTE>
“Slow response”
Old 04-08-2004, 08:30 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by belezeebub:
Here's a pic of the 325/60R20 on a 20x11" rim. <HR></BLOCKQUOTE> <HR></BLOCKQUOTE>
Compared to stock you'd gain .7"
I added stock tires to the list below.
315/70R17 - 34.5" tall - 12" wide
325/60R20 - 35.2" tall - 12.9" wide
Old 04-12-2004, 04:15 PM
Any ideas anyone?
Old 04-12-2004, 04:34 PM
Circuitguy
I just installed a set of 20x10 Racelines with 325-60-20 Nitto Terragrabers and they fit fine. They do rub in the front only when you turn all the way left or right. Its only hitting the plastic wheel well a bit, not too bad. BIG-C
Old 04-12-2004, 04:37 PM
Circuitguy
Here is one more! BIG-C
Old 04-12-2004, 05:06 PM
H2, I believe the 325/60 Nittos are only about 33" tall. They were installed on mine at the dealer. I took it back and they put the correct one's on, 325/65. If I remember my math correctly, the 65's are a few hundredths taller than stock.
Nevermind, that applied to 18" rims, not 20's.
http://www.ringpinion.com/calculators/calctireh.html
Old 04-12-2004, 06:40 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Circuitguy:
I just installed a set of 20x10 Racelines with 325-60-20 Nitto Terragrabers and they fit fine. They do rub in the front only when you turn all the way left or right. Its only hitting the plastic wheel well a bit, not too bad. BIG-C <HR></BLOCKQUOTE>
Those look great Big-C. Thanks for the pic to my e-mail as well. Where is your shop located and what do you sell? I live 40min away from you.
Old 04-13-2004, 12:26 AM
Hummer Man is off the scale
NO - fronts will rub of road on moderate trail activity.
Old 04-13-2004, 01:52 AM
Phil, I remember reading somewhere about guys removing their swaybars when they wheel. Apparently it allowed for more articulation. Now I know the truck will "sway" more, but have you tried it or seen it done? If so, what was your impression?
Old 04-13-2004, 03:50 PM
Circuitguy
Since you are local email me with your number so we can have lunch or something. BIG-C
If I have to lift it I'd go with 38's or 40's as I prefer the full wheel well look. <HR></BLOCKQUOTE>
